by Akini123 Investigator
My mobile data doesn't work anymore for my Samsung Galaxy J3 (2016) phone?
As of August 2017 I have not been able to use my mobile data at all dispite having good signal and actually having data, any help would be appreciated
Re: My mobile data doesn't work anymore for my Samsung Galaxy J3 (2016) phone?
  • Does this only happen in one location?
  • Have you checked for local issues with EE network?
  • Have you accidentally disabled data? (scroll down from the top and toggle the data option)
  • Try restarting your phone?
Thank you for the quick reply, my data does not work in any location and my local area is covered by EE's super fast 4G. Finally how do I check if I turned off data?
Regards Akini Thomas
Sent from my Samsung Galaxy smartphone.
Morning @Akini123
Thanks for coming here.
Can you select your Home button then go to > Apps > Settings > Data usage.
Does this show off or on?
Thanks, Leanne.
