Highlighted
by Contributor
My extra addon data has been zeroed before the 30 day period ended
I got a tad happy go lucky with my data, so bought the £20 10G data addon. Which is meant to last 30days. I used just 2G of this by the time my contract data was renewed. Expecting to have 18G to play with. But no. Just 10G??
Highlighted
by Ace Contributor
Solution
Re: My extra addon data has been zeroed before the 30 day period ended
HI,
@Nickriding
  • The add-on lasts until your next bill or until the data runs out
  • The time starts the minute you buy it
  • Data bought as an add-on will only be used after your plan data allowance has run out
  • Add-on data won't be carried over if your allowance refreshes
That is clearly on http://add-on.ee.co.uk/purchase
When you purchase extra data.
Highlighted
by Ace Contributor
Solution
HI,
@Nickriding
Highlighted
by Profile closed
Not applicable
Hello @Nickriding data add ons last until one of the following:
  • The 30 days has expired
  • Your billing cycle renews
  • The data is used up
http://ee.co.uk/non-standard-prices
Highlighted
Fantastic help @tahirmian and @Profile closed
Hope to see you back in community again soon @Nickriding
Cheers
Richard
