by Luckyfella
My data went down by 5g yesterday even though wifi and mobile data switched off.
My data allowance went down by 5g whilst I was at work yesterday. I had wifi and mobile data switched off and as I'm single there was no one at home using anything (I have a shared data plan). Is there anyway of checking what the data was used on?
by Luckyfella
Re: My data went down by 5g yesterday even though wifi and mobile data switched
Just to update this, I've just replied to 2 emails and spent 2mins on face book and data has gone down a further 1.2g. At this rate I will get through my 20g allowange in about 5days. I've been on the same plan with the same equipment for over 2yrs and never had a problem with having enough data. Any ideas?
Hi @Luckyfella
Check out our How much Internet data are you using supporting article. There are some great tips on there for managing your data.
I also recommend turning off video auto-play on your Facebook app.
What is the make and model of your device?
I'll do my best to help more.
