Highlighted
by Valued Contributor
Valued Contributor
My EE app not logging-in anymore
I'm getting "Sorry, Something's gone wrong. it's our fault ... please try again
The My EE app was logging-in ok last week,
So far, I've tried:
Uninstall/reinstall app, clear app storage & cache, login via fingerprint and via PIN, Login over WiFi / Login over 3/4G & both
I can logon  to myaccount.ee.co.uk from my Pc Ok
Any ideas ?
12 REPLIES 12
Highlighted
Re: My EE app not logging-in anymore
@Tom__Hall.  this error happens from time to time and give it some time and you’ll probably find it’s working again.
Highlighted
Hello there @Tom__Hall
Thanks for posting on the community.
What phone are you using?
Can you use all other apps ok at the moment?
Thanks, Leanne.
Highlighted
Valued Contributor
Hi @Leanne_T
I've got a Nexus 6P, running stock Android 8.0.0, phone is not rooted
All other internet-type apps are working fine, and those that need to, login Ok to Microsoft, & Google
As I said in my OP, the My EE app worked / logged-in Ok last week
Highlighted
Thanks for coming back to me @Tom__Hall
In this case please give us a call.
Our technical team will be able to get this looked into further for you.
Let me know how you get on 🙂
Highlighted
Valued Contributor
Hi @Leanne_T
As requested, I phoned up support, and told the Level1 lady everything I'd done etc.
She contacted Level2, and came back with the following rather "unusual" answer ...
Basically, they are saying that it's because (last week), I ordered (a Pixel 2 XL), and that now my account is in an "open" status because of that order
She said that once I get my order, my account will update, everthing will be Ok, and the app will be able to login on my mobile.
Of course I queried why I can login on my PC, but not on my phone, and was told "because the app accesses the account differently"
So, that's it, sounds so improbable, it must be true ?
-Tom
Highlighted
Hi @Tom__Hall
Thanks for calling.
Have you tried deleting the app and reinstalling this?
Thanks, Leanne.
Highlighted
Valued Contributor
Oh yes...
>So far, I've tried:
>Uninstall/reinstall app, clear app storage & cache, login via fingerprint and via PIN, Login >over WiFi / Login over 3/4G & both
Highlighted
Thanks I just noticed this above as well sorry @Tom__Hall
In this case I would suggest another call into customer service to get this looked into further.
Thanks, Leanne.
Highlighted
Valued Contributor
Hi @Leanne_T
Don't you beleive the explanation they gave yesterday (about the open order) ?
Highlighted
Hi @Tom__Hall
Without account access I couldn’t say what was the cause of your app now not working.
It is strange your online account is fine and it's just the app, which would need further investigation.
Thanks, Leanne.
Highlighted
Valued Contributor
Hi @Leanne_T
They (Level 1 & Level 2), say it's a feature of the way the app handles account logons which have an open order - apparently a web logon via a PC handles things differently
As long as I can check my order via the web, I'm a happy bunny, but if you want me to ask support  again, I will - up to you
Highlighted
Hi @Tom__Hall
No problem let me know how you get on with the app when your new phone arrives.
Thanks, Leanne.
