by Mamps Investigator
Mobile data not working
Hi I am using iPhone 6s and since yesterday my data not working
It shows 4g on top corner but doesn’t connect to internet. WiFi works fine. I still have 4gb data left out of 10gb and I have tried resetting network settings but no luck
any help please!!
10 REPLIES 10
by Brilliant Contributor
Re: Mobile data not working
Hello @Mamps,
Welcome to the community,
Have you tried re-booting your phone, taken the sim card out, given it a wipe and put it back in again to see if either of these work?
It could also be a case that you need a replacement sim card if neither work. You can either get a replacement sim card from an EE store or by ordering online, but before that, are you able to try the sim card in another phone? If not, by going into a store, they will be able to check this for you.
Is mobile data active?
Afternoon @Mamps
Thanks for coming here.
Has the helpful advice given got this working for you?
Speak soon, Leanne 🙂
Yes mobile data is active but no internet
I have also tried phone off and took out SIM card but nothing worked.
i just done my upgrade yesterday is that to do with anything??
Hi @Mamps
Did you get a new SIM yesterday?
Also, is this in the one area?
Thanks, Leanne.
Same old sim and same old area
EE Employee
Hi @Mamps
Are you able to call and text?
What happens when you pop over to http://add-on.ee.co.uk/status ?
Many thanks,
Lee
My allowance suppose to reset today
and now all working fine but still don’t know why it wasn’t working yesterday even tho I had 4 GB of data left.
but thanks for all your support
EE Employee
Brilliant @Mamps
I'm glad you are now sorted 🙂
Cheers
Lee
