Highlighted
by Investigator
Kik not working abroad
Kik working till I arrived in Lanzarote
All other apps working
6 REPLIES 6
Highlighted
by Investigator
Was working at
Was working at home not now in Lanzarote
Highlighted
Re: Kik not working abroad
Hello there @Ian1026
Hope you are having an amazing time 🙂
Are you using WiFi or data?
What happens when you try and use the app?
Also what device are you using?
Thanks, Leanne.
Highlighted
by Investigator
Data on a 4g ee max plan
App just says delivered
WhatsApp works fine
Highlighted
Thanks @Ian2016
What device are you using?
Thanks, Leanne.
Highlighted
by Investigator
Galaxy S8
Everything else is fine
Highlighted
Thanks @Ian2016
If everything else is working for you this sounds like a problem with the app.
Can you test this over WiFi and see if this works for you?
Thanks, Leanne 🙂
