Highlighted
by Investigator
Keypad doesn't stay up on phone when using text
When I'm trying to text or use what's app my keypad want stay up on my phone it pops up then goes off again any ideas
10 REPLIES 10
Highlighted
Re: Keypad doesn't stay up on phone when using text
  • What phone do you have?
  • Have you installed another keyboard?
Also go into settings - language and keyboard and ensure your correct keyboard is selected.
Highlighted
by Contributor
If you go to the app store or click the link below and install Swiftkey this could hlep your keyboard issues.
https://play.google.com/store/apps/details?id=com.touchtype.swiftkey&hl=en_GB
Highlighted
by Investigator
I have a Samsung galaxy 6edge
Not installed any keyboard
Highlighted
by Investigator
Hi installed but it still not staying in the keypad justices off every time I go to type
thank you,
Highlighted
by Investigator
Hi installed but it still not staying in the keypad just goes  off every time I go to type
thank you,
Highlighted
by Investigator
key board in settings is showing as Samsung keyboard
not installed  any other keyboard
thank you
Highlighted
by Contributor
  • go to settings
  • general management
  • language and input
  • on-screen keyboard
  • samsung keyboard
  • scroll to bottom and reset to default settings.
Highlighted
If the above doesn't work go into settings - applications management - find the keyboard and wipe/delete the cache/data.
See if that helps.
Highlighted
by Investigator
Hi
thanks for all your help still not working. Will go into the shop to see if they can resolve it for me,
thanks again
Highlighted
EE Employee
Hi @Doseyrosey68
So I can try and assist and save you a trip out, please can I get you to pop your phone into safe mode to see if your problem occurs there.
Enter SAFE MODE
This could help in troubleshooting unstable or strange behaviour issues.
  1. With the phone turned off, press the Power button for a few seconds.
  2. As soon as the screen lights up, release the power button and then hold the Volume Down button until the home screen appears.
NoteTo exit safe mode, simply turn off and back on.
Once it is in safe mode try using keyboard etc.
Do let me know if this helps,
Lee
