Highlighted
by Investigator
Keeping number after upgrade
Hi. Just upgraded to the max plan and got the S9 in the process. I want to keep my number... is it as simple at putting my existing SIM card in to this new phone? I'm not very savvy with all this stuff.
6 REPLIES 6
Highlighted
by Profile closed
Not applicable
Re: Keeping number after upgrade
Yes, if your existing SIM card fits, after you upgrade you can just carry on using your existing SIM card if you want to.
Highlighted
by Brilliant Contributor
@Youareannoying1, You will keep you number, as that is what upgrade means. Your existing  SIM card should work with your new phone, if you have any problems with your old SIM card, you can request a replacement SIM card either online or in an EE store.
When I got a new phone and upgraded to the max plan, just put my old SIM card in the new phone. Hope this helps.
Highlighted
Morning @Youareannoying1
I can see you have had some great advice already, does your SIM work in your new phone?
Did you get a new SIM card with the phone?
Thanks, Leanne 🙂
Highlighted
by Investigator
Yes. All sorted now. My new S9 is fantastic.
Highlighted
Great news @Youareannoying1
It looks amazing, I am very jealous 🙂
Highlighted
@Youareannoying1, thank you for letting us know, glad you got it all sorted and our replies helped you.
