by Deeds44
Iphone6 going straight to voicemail. Message says voicemail off. It is not!
When calling my number iPhone 6 goes straight to voicemail where caller is told my voicemail is turned off. My voicemail is on enhanced messages. How do I fix this? And how do I get my phone to ring prior to going to voicemail.
by Ace Contributor
Re: Iphone6 going straight to voicemail. Message says voicemail off. It is not!
Hello @Deeds44 have you turned voicemail on by texting the code VOICEMAIL DIVERT to 150? You can still access the menus and settings by calling 222 even when it is turned off.
EE Employee
Hi and welcome to the community @Deeds44
Please can I get you to first dial ##002# and let me know if this helps.
Has the advice given by @tm90 also helped at all?
Many thanks,
Lee
