by Podman Established Contributor
Re: Internet keeps dropping
the fact that your pc stayed connected but your xbox reported problems with DCHP should have highlighted to customer support that the router was the issue not your line.
I have had a number of routers over the years and after about two years or so they all start to do similar devices aren't able to connect while others are. Build in Obselesence !
A new router should solve your issues. Have you tried setting a specific IP for your xbox in the router via mac address.
Glad you are now up and running but sorry you had to wait on engineer visit for appears to have been an easy to spot issue.
Thank you for posting @Podman
Hope to see you posting again in community to try and offer support to others.
Cheers
Richard
by Drifty Established Contributor
problems started again
Loss Of Signal Defect 4 & 2
Over what period?
18 hours
it so bad it is I mean look at my speed test
speedtest
so Bad the drops the bad speed it is so bad
As you've removed the images of your router stats I can't tell how good or bad that speedtest is. It's certainly nice & flat.
Please copy & paste your current full router stats here inline in a post.
I'v rebooted the router last night which I have done 14 times in last 2 days but speed still way low
DSL Status
System Uptime is: 09:47:59
After Reboot my speed is speedtest this is still not even haft of what the speed meant to be
You shouldn't be doing that that often. It'll think the line is faulty.
That speedtest is consistent with your router stats, which seem about right. What do you think it's meant to be?
speed should be between 60 and 78mb
and there been 3 lost of signal since my last post and speed droped to 3 to 5mb
speedtest/1506900068342802955
DSL Status
What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
When you login to your Member's Centre @ https://web.orange.co.uk/r/login/ what does it say about Estimated Line Speeds under Your broadband speed ?
Estimated Fibre Download Speed is 59.3 Mb/Sec
Estimated Fibre Upload Speed is 20.0 Mb/Sec
and right now this is what it is
just tried to ring all I got was a buzzening sound no voice nothing
then I use my moblie and kept saying high number of calls then atfer 10 mins it cut off
So after 5 trieds I went to a EE shop turns out the customer services is down no wonder why I could't get through
Hi @Drifty,
I'm sorry to hear you are having difficulties getting connected with customer services.
Please try again later.
I have and I can't get through i go through all the options and wait hear about things to try and that there a high demand then 20 mins or so later it just hang up on me
my home Phone I can't even make a call it buzzing on the line no dail tune nothing
It a joke and I'm about had enough 7 months been EE not one Month have it been problem free not one it just problems after problems after problems and now I can't even get any customer services what you do in my shoes?
I appreciate your frustration, @Drifty.
The only team that can help with this are based in the call centre.
Fingers crossed you can get through soon.
Your not listening I can't even get through I wait and Wait and it just hang up on me no one answer the call it just hang up on me Swear to god getting so p**s off now with this Company.
Apologies, @Drifty.
I should have added a bit of context around my response.
Due to a previous internal issue there may be a delay in contacting the EE teams.
The only thing I can advise in relation to your query is to try again.
