10-09-2017 04:07 PM
no change still disconnecting
11-09-2017 08:17 AM
Hi @Drifty.
I'm disappointed to see that you broadband connection is still dropping.
I recommend giving our technical support team a quick call to give them this update. They will then be able to escalate this further.
Please let us know how you get on.
13-09-2017 04:09 PM
Got a new router on the way if this dont work then there nothing left other then replace the whole line from my place all the way to junction box
13-09-2017 04:21 PM
Fingers crossed that sorts the problem out, @Drifty.
Keep us updated, I'm sure there are a few people on here that would be interested in the outcome.
Chris 🙂
16-09-2017 10:05 AM
ok new router arrived and has been up and running for 19 hours so far (touch wood) it been ok no disconnect or lag give you another update in 5 days or so
16-09-2017 10:34 AM
17-09-2017 04:07 PM
is there a way to turn off lease time it keeps disconnecting the xbox
17-09-2017 05:26 PM
The Lease Time defaults to Forever. You can only make it shorter!
17-09-2017 11:13 PM
ok well I'm still having problems then xbox keeps losing internet both wired and wireless there no report in the log about lost of single or anything other then lease time is up for xbox
18-09-2017 12:31 AM - edited 18-09-2017 12:38 AM
You sure the XBox is not setting its own IP & therefore lease time? You sure the router has Lease Time = Forever?
Please post verbatim this log msg about lease time up.
18-09-2017 01:11 AM
17:25:18, 16 Sep. Device connected: 192.168.1.73, 50:1a:c5:c9:a2:14, XboxOne, lease time is 172800 seconds
17:25:17, 16 Sep. Device connected: 192.168.1.73, 50:1a:c5:c9:a2:14, XboxOne, lease time is 172800 seconds
17:25:05, 16 Sep. Device connected: 192.168.1.73, 50:1a:c5:c9:a2:14, XboxOne, lease time is 172800 seconds
17:13:33, 16 Sep. Device connected: 192.168.1.73, 50:1a:c5:c9:a2:14, XboxOne, lease time is 172800 seconds
17:13:30, 16 Sep. Device connected: 192.168.1.73, 50:1a:c5:c9:a2:14, XboxOne, lease time is 172800 seconds
17:13:27, 16 Sep. Device connected: 192.168.1.73, 50:1a:c5:c9:a2:14, XboxOne, lease time is 172800 seconds
17:13:26, 16 Sep. Device connected: 192.168.1.73, 50:1a:c5:c9:a2:14, XboxOne, lease time is 172800 seconds
this one of the time it just kept disconnecting
and I cant find the lease setting in the router
18-09-2017 01:22 AM - edited 18-09-2017 01:50 AM
Duh! That's a Lease Time of 2 days!
Set it Forever under DHCP.
18-09-2017 10:18 AM
i'v disable it
18-09-2017 12:47 PM
Disabled what? You can't disable the DHCP or it won't work.
18-09-2017 01:40 PM
yeh I changed it to forever we see how it goes
19-09-2017 05:40 PM
I was getting dns address problems also so I changed the dns address
For those who may want to try this login to router http://192.168.1.1 and then go to ADVANCED in broadband setting u see
DNS IP Address it be auto change to manual
then Primary DNS 8.8.8.8
Secondary DNS 8.8.4.4
then click save setting
so far that stop the dns address problem
19-09-2017 06:59 PM
23-09-2017 03:40 PM
ok so it been a week or more since i had all these problems and it been good so far.
I have done a tip and trick that may help users you see that here at EE-broadband-tips-and-tricks hope it helps
David
24-09-2017 10:37 AM
Subject |
