Highlighted
by Investigator
Internet connection randomly dropping oit
Hi there.
The internet is randomly dropping out. It make go off for a minute or so and then come back on. It can happen in quick succession or it can go for lame hours with no issues.
I've posted a few bits  below but removed ip  addresses.. I did a power cycle today but only because I had to move the router to plug in a wired device. Usually it doesn't get switched off.
Online Status
Physical Connection System Uptime: 0day 1:12:56
IPv4IPv6
LAN StatusPrimary DNS: Secondary DNS:
  192.168.1.1804052605092
WAN 1 Status>> Drop PPPoA
  Enable Line NameModeUp Time
  Yes ADSL wanadooPPPoA0:26:01
  IP GW IP TX PacketsTX Rate(Bps)RX PacketsRX Rate(Bps)
     23982918762409850736751
ADSL Information       ( ADSL Firmware Version:  2471201_A)
  ATM StatisticsTX CellsRX CellsTX CRC errsRX CRC errs
  4948511139294305
  ADSL StatusModeStateUp SpeedDown SpeedSNR MarginLoop Att.
  ADSL2+(G.992.5)SHOWTIME11340006656000830
8 REPLIES 8
Highlighted
Re: Internet connection randomly dropping oit
If you would like help with your speed or connection issues, please would you carry out the steps and provide the data as requested in the Need Help with Your Home Broadband Speed or Connection? sticky. This will enable us to diagnose the problem and advise you further.
Highlighted
by Investigator
Thanks for replying. Updated my initial message as when I tried to type into the body originally, it kept taking me to another EE page rather than allowing me to type. I'm using my mobile for this.
I will do the steps you suggest later when I get time today.
Highlighted
Sorry, that page is incomplete. We're looking for a page with Attenuations & Noise Margins. Think it might be below what you posted (ADSL Info).
Highlighted
by Investigator
It's a Draytek 2710 so I'll have to telnet into it later to get the stats you need.
Thanks for your help so far though.
Highlighted
by Investigator
l telneted in to the router just now and below is what it gave me.
Its lost the internet several times today. Sometimes it might do it 2-3 times in quick sucession and then be find for a couple of hours.
I only siwtched it on and off once today and that was earlier this morning and I needed to move it slightly so I could plug wire in my laptop ethernet cable.
Any advice gratefully received, Thanks.
--------------------------- ATU-R Info (hw: annex A, f/w: annex A) -----------
Running Mode : ADSL2+(G.992.5) State : SHOWTIME
DS Actual Rate : 6656000 bps US Actual Rate : 1110000 bps
DS Attainable Rate : 11200000 bps US Attainable Rate : 1334154 bps
DS Path Mode : Interleave US Path Mode : Interleave
DS Interleave Depth : 192 US Interleave Depth : 1
NE Current Attenuation : 30 dB Cur SNR Margin : 9 dB
DS actual PSD : 19. 0 dB US actual PSD : 12. 8 dB
ADSL Firmware Version : 2471201_A
-------------------------------- ATU-C Info ---------------------------------
Far Current Attenuation : 15 dB Far SNR Margin : 5 dB
CO ITU Version[0] : 00005453 CO ITU Version[1] : 00005443
DSLAM CHIPSET VENDOR : < TI >
Highlighted
On the discon issue, your router gives no error counts, so that avenue of investigation is out.
How long has this been happening?
Reboot the router & try plugging it into the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets? Are there any wires connected to back of faceplate?
Post the full router stats & System Uptime when plugged into test socket.
Is the issue any better?
Try the BT Quiet Line Test (dial 17070 Opt 2), preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
On a speed front, it's going rather slow. You should be syncing at about 15 Meg instead of the 6656 K that you are. The reason you are not is that the DLM system has put you on a banded profile in response to past errors on your line, at the top of the 7th lowest of these ADSL Banded Profiles. You need to give the DLM time to relent & remove any banding. Leave it alone for at least 7 days & don't reset or resync the router. If it's still banded you should then call EE to get the DLM reset in order to remove any banding. However should significant errors persist the DLM will reapply banding.
Have you had any faults fixed with your line recently?
Highlighted
by Investigator
Thanks for confirming that. I will undertake what you suggest when I next get time.
The route will be plugged into an extension socket that's for sure.
Highlighted
That could well be the issue if your house wiring isn't perfect.
