Highlighted
by Investigator
Intermittent broadband
we recently moved - the EE service at our old address was very good. Since moving, and allowing nearly a month for it to 'settle' speeds are slow with at least 2-3 drops in service each day.
Mirofilter has been put on. Most recent stats are;
DSL
Data rate info: upstream 383, downstream 1999
defect/failure
noise margin upstream6.1 downstream 9.3
line: upstream 0 downstream 53.9
system update is: 01:07:23
downloads speeds showing at 2 - indicative speeds are 80
Highlighted
by Brilliant Contributor
Re: Intermittent broadband
Hello @Louisa568,
Welcome to the community,
So that @XRaySpeX or anyone else for that matter, can help you, can you check here and include the information as per the following page:
https://community.ee.co.uk/t5/Broadband-home-phone/Need-Help-with-Your-Home-Broadband-Speed-or-Conne...
Highlighted
Also, what does BT Broadband Availability Checker estimate for your phone number? Post just the table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
