by Biggibby
If I listen to the radio on a downloaded app on my phone does it use up my data
by Ace Contributor
Solution
Re: If I listen to the radio on a downloaded app on my phone does it use up my d
Hi
@Biggibby Yes it will if use app to listen radio .
Many thanks
by Ace Contributor
Solution
Hi
Many thanks
EE Employee
Hi and welcome to the Community @Biggibby
Yes, a radio app would use your mobile data allowance which is included in your package.
WIFI would be free.
Many thanks,
Lee​​​​​​​
Not on WiFi, @Lee_H, at least not from EE mobile data allowances for which you pay,
Thanks, @Lee_H, for correction. That's exactly what I would've said.
EE Employee
Hi @XRaySpeX
Thank you for that, I may not have been very clear in my post I have now edited my response.
Many thanks,
Lee
by Biggibby
Ok ta
Sent from my iPhone
