Highlighted
New Member
I used to be able to check usage on shared plan in % , can't seem to do it now
I have 4 phones on a shared plan, i used to quite easily view the percentage of each user, the web site and the app no longer seems to support this, can anybody tell me otherwise please
Highlighted
EE Employee
Solution
Re: I used to be able to check usage on shared plan in % , can't seem to do it n
Hi @rulli61 and welcome to the community.
We’ve made some big changes to the My EE app & simplify the experience.
we’ve removed the shared data listing functionality temporarily.
Shared data can now be found on http://add-on.ee.co.uk/ (using the phone browser).
Many thanks,
Lee
Highlighted
by Brilliant Contributor
@rulli61 The app no longer supports itemised usage since they updated it for some reason they took the function out!
@Lee_H are you able to confirm weather this should still be visible on my EE?
Highlighted
EE Employee
Solution
Many thanks,
Lee
