by dianepaularry
I’m in the USA and my mini device is not working. Any advice?
The 4G light is red and I cannot get a connection.  Any advice please
by Star Contributor
Star Contributor
Re: I’m in the USA and my mini device is not working. Any advice?
Hi @dianepaularry
Is your device on a pay monthly or payg plan?
If it's pay monthly, can you login to your account, under device, check if roaming is enabled?
Thanks,
Martyn
by Profile closed
Not applicable
@dianepaularry @martyn413 EE WiFi devices (both the mini and the full size one) won't work in the USA as they don't have the correct 4G/LTE band or even the 3G bands to work in the USA unfortunately.
They are only designed to work in the UK and Europe.
EE Employee
Hi @dianepaularry and welcome to the community.
Unfortunately, as @Profile closed has mentioned the devices are not compatible for roaming outside of the UK and Europe.
Many thanks,
Lee
