Highlighted
by Investigator
I have a solid orange broadband light on my bright box router.
I have had EE fibre for years with no complaints.  Since i have had it i have had a solid Orange broadband indicator light on my router.  In the past this hasnt seemed to impact my service so j have left it.  However, seens upgrading my tv service to sky q, have had a lot of messages stating "you are experiencing broadband issues" and my content isnt loading.  As everything else is working ok, can only assume it has something to do with this solid orange light.
Have tried my sky box via wifi and ethernet directly into the router
I have a 75mb unlimited staff plan so speed shouldnt be an issue
Highlighted
Solution
Re: I have a solid orange broadband light on my bright box router.
Try switching the DNS settings in router to Manual with a public DNS:
Open DNS  :	208.67.222.222 & 208.67.220.220
Google DNS:	8.8.8.8 & 8.8.4.4
Norton DNS:	198.153.192.40 & 198.153.194.40
That has been shown to help other Sky-Q issues.
8 REPLIES 8
Highlighted
@law00b1   Have you tried resetting the router?  There is a small hole on the router with the words reset next to it.  Push a pin in the hole and hold it there for 30+ seconds and this will reset the router.
Highlighted
What does it say in the Internet section on the initial Status page of the BrightBox after you log in? Obscure your names in the BB Username but post the 1st 2 parts of the IP addy.
Highlighted
by Investigator
Hi Chris_B
Yes - tried resetting the router, have had the filters replaced several times, had a replacement bright box - to no avail. Previously just annoying having a rogue orange light on the router but as mentioned seems to be starting to impact certain services now
thanks though
Highlighted
Let me know the Internet Status as reported by the router & we can go from there.
Highlighted
by Investigator
this is the status page XRaySpeX - the post had invalid HTML removed so hope it makes sense - thanks
Internet
Broadband Type Fibre Broadband
State Connected
Internet State Connected
Time Connected 252:34:15
Downstream Rate 79.99 Mbps
Upstream Rate 20.00 Mbps
IP Address 95.149.35.107
IPv6 Address N/A
IPv6 Prefix ::/0
WIRELESS
Wireless Network Name (SSID) Band Type Security Channel SSID State Broadcast SSID EE-9m39m7 2.4GHz WPA/WPA2 1 Enabled Enabled 5GHz-EE-9m39m7 5GHz WPA/WPA2 48 Enabled Enabled
Highlighted
Well, you are fully connected at full speed, so it must be a faulty LED. Solid Orange is not a state for the BB light
Broadband
Solid green
The router is functioning correctly, and is connected to broadband.
Flashing orange
The router is synchronising with broadband.
Red
The router can’t detect a broadband signal. Check that the grey broadband cable is connected to the DSL/fibre port.
Solid Green is the state it's in.
So your issue with the Sky Box must be something else which I'll now consider. I think I've seen it somewhere else.
Highlighted
Solution
Highlighted
by Investigator
thanks  - switched the DNS as suggested and has seemed to improved things.
Will keep monitoring
thanks again
