by Nokia6 Investigator
I have a new nokia6, but can't send or receive texts
 I have a new nokia6, but can't send or receive texts (Error 50). Calls are fine.
What's the problem?!
6 REPLIES 6
by Brilliant Contributor
Re: I have a new nokia6, but can't send or receive texts
Make sure the message centre on the phone setting is set to the correct number.
+447958879879
BrendonH (Android Expert) Samsung Galaxy S10+ (Android 10/One UI 2.0)
...but where exactly do I find that?
I'm new to Android
Open up messages. And open settings
Then within there are the option to change the number.
Hi @Nokia6
I see @BrendonH has offered some brilliant advice already.
Did that fix your text messages?
Please let me know if you need some more help.
Chris 🙂
Actually, the menu screen wasn't teriffically intuitive, and the only place I managed to find the message centre number was by 'dialing' *#*#4636#*#* and hitting 'refresh'.
Apparently, though - according to EE Customer Services - Carphone Warehouse hadn't properly registered my sim/phone number, so I'll go back to them today and see what happens!
Thanks for getting back to us @Nokia6
At least we know what is causing this. Let us know how you get on once you've spoken to Carphone Warehouse.
Chris 🙂
