Highlighted
I cannot use my data on an iPhone 7
I just topped up for a £15 pack this morning, and I can text or call normally. I have reset my network but it did nothing.
Highlighted
Solution
Re: I cannot use my data on an iPhone 7
Thanks for your response I have sorted it now the parental lock was on so it appeared as though my internet wasn’t working as videos weren’t loading on
Facebook and similar sites
6 REPLIES 6
Highlighted
@Carriess  Is mobile data switched on on the device?  Have you allowed the apps to use cellular data?
Highlighted
Hello there @Carriess
What happens when you try and use the internet?
Also what device are you using?
Hope to hear back from you soon 🙂
Highlighted
I have the same
issue with my iPhone10  im
on pay as you go tried resetting network settings updating phone mobile data is on WiFi is off I have loads of data
Highlighted
Hi @Nat30.
Welcome to the community.
Do you have a 4G symbol in the corner of your phone?
Is your mobile data switched on?
Jon
Highlighted
Solution
Highlighted
Glad you're sorted, @Nat30
Thanks for letting us know. 🙂
