Highlighted
by Investigator
I can't go on safari on 3G
I can only connect when on wifi. On 3G however I can connect to all my other apps. It's just safari. It comes up with a message of 'safari cannot open page because your iPhone is not connected to the internet'. I have tried to reset network settings. This has not worked
Highlighted
Solution
Re: I can't go on safari on 3G
@Yasminemillen  On this image do you have the top toggle on ?  And to enable Safari just toggle the toggle next to Safari.    This image is just to show what should be on and it’s not showing the correct app for Safari.
13 REPLIES 13
Highlighted
@Yasminemillen  Have allowed Safari to use cellular data ?
Highlighted
by Investigator
How do I do that?
Highlighted
by Investigator
Highlighted
@Yasminemillen  Go to Settings>Mobile data and make sure the toggle is on.  ( green)
Highlighted
by Investigator
@Chris_B it's not how do I change it?
Highlighted
Highlighted
by Investigator
@Chris_B it won't let me ...
Highlighted
Solution
Highlighted
by Investigator
@Chris_B Ah didn't realise you needed to turn mobile data on in order to change the toggle. Thanks 🙂
Highlighted
@Yasminemillen  That toggle at the top has to be on all the time to use cellular data if it’s off your not going to use cellular data at all,  that toggle is the master control toggle that will turn off cellular data all together.
Highlighted
Thanks for helping @Chris_B
Let us know if you need anything further @Yasminemillen.
Have a great day!
Highlighted
Solved, thank you to the previous posts which really helped 😃🤓
Highlighted
Great news @Dee01
Glad you got the help you needed from the community 🙂
Have a great weekend.
