Highlighted
by Contributor
I can't call international numbers
12 REPLIES 12
Highlighted
by Ace Contributor
Re: I can't call international numbers
Hello @Mikee_reid are you on EE, T-Mobile or Orange? PAYG or pay monthly?
Highlighted
by Contributor
Orange, pay monthly
Highlighted
by Ace Contributor
Which country are you trying to call? Have you been able to call abroad before?
Highlighted
by Contributor
Norway & Sweden. I've checked that my roaming is on. I managed to whatsapp call the uk from Sweden but I guess that's using data
Highlighted
by Ace Contributor
Are you in the UK or Sweden right now? Are you using the correct international format when calling (+47 for Norway and +46 for Sweden)?
Highlighted
Hi @Mikee_reid
Welcome to the community. 🙂
Did @tm90's advice above help?
If not, could you confirm if you're in the UK or abroad.
Highlighted
by Contributor
I'm in the uk at the moment. Yes I have the correct codes for Norway & Sweden
Highlighted
by Contributor
Hi Chris,
yes I'm in the uk. When ever I try & phone a Norway or Sweden number there's an automated message telling me these numbers are barred from my phone. Any help would be appreciated as I'm going to Norway on Tuesday
Highlighted
Thanks for confirming, @Mikee_reid
It sounds like you may have an international bar on your phone.
Our customer service team should be able to have a look into that and remove it for you.
Please let us know how you got on, once you've spoken to them.
Highlighted
by Contributor
Hello Chris,
i called led customer support & they managed to reset my roaming account & it seems to have fixed the problem. Turns out there was call barring on my account for some reason.
Thanks for all the help
mikee
Highlighted
by Contributor
Hi TM90,
i called the customer support & they managed to reset my roaming account & it seems to have fixed the problem. Turns out there was call barring on my account for some reason.
mikee
Highlighted
EE Employee
Brilliant @Mikee_reid
I'm glad you are now sorted.
Many thanks,
Lee
