Highlighted
by Established Contributor
Huawei P10 and P10 Plus: does EE sell the dual sim version?
As per the subject: does EE sell the dual sim or the single sim version?
Highlighted
Solution
Re: Huawei P10 and P10 Plus: does EE sell the dual sim version?
You only get the single sim version in the European markets so EE versions are single sim.
6 REPLIES 6
Highlighted
Solution
Highlighted
If I get a non-European dual sim version (easy on ebay), would it work with EE's wifi calling? EE says that the P10 plus works with its wifi calling even when not bought through them, but it's not clear if this applies to non-European dual sim versions.
For example, the non-European Galaxy s7 dual sim does not work with wifi calling, but there are reports of people who got it to work by flashing a different firmware.
Btw, I need a dual sim to have my private sim and my work sim at the same time, without the inconvenience of carrying a second phone.
Highlighted
Hi, @garfieldthecat
I couldn't say for sure but you are correct that the dual sim mobiles are for non European markets. If I was a betting man I would say no because the firmware is different because of the hardware.
You could try flashing European firmware but again I would say it wouldn't work because of the firmware/hardware compatibility. Even of it did work it's unlikely you could use the dual sim.
Highlighted
Yet there are reports of people who have managed to do just this (flash a European firmare on their non-European dual sim version, while retaining dual sim functionality) with their Galaxy S7 edge. I wonder if the same can be done with the P10 plus...
Highlighted
by Investigator
Hiya
I have a dual sim p9 p20 and htc u all from ee,
I don't think they know what there selling?
Ee might not support dual sim but the phones they sell do.
Highlighted
@Alloycat  From what store did you get these ?
