Highlighted
by Investigator
How do I unlock my I phone after I've received my code
Highlighted
Solution
Re: How do I unlock my I phone after I've received my code
@Sparhawk   As it's a iPhone you don't actually get a code.  You just need to put a different network SIM card in the device and that's it.
    But if it's a iPhone 4s and below you need to then connect the device to iTunes on a PC and it will say you have a carrier update just click "yes" to install that update.
10 REPLIES 10
Highlighted
by Brilliant Contributor
@Sparhawk If you have received the sim unlock code you need to put in a different network sim it will then ask you for the code enter it and it's unlocked
Highlighted
Solution
Highlighted
EE Employee
Hi and welcome to the Community @Sparhawk
So I can try and assist, please may I know what type of phone it is that you are trying to unlock.
Many thanks,
Lee
Highlighted
by Investigator
Re: just keeps saying sim unsupported
Highlighted
by Investigator
I phone 6
Highlighted
@Sparhawk   You need to put a SIM card that is activated by the network that the SIM card is from.    Is the SIM card your putting in the device activated?
Highlighted
by Investigator
Yes it is
Highlighted
Highlighted
by Investigator
3
Highlighted
@Sparhawk   Haha.   I thought it might be.
 3 SIM cards can have this issue of not allowing the unlock to progress,   Can you get a O2 or a Vodaphone SIM card.
