Highlighted
How do I set up wifi calling on a Samsung S7 bought outside the UK?
I'm on a monthly ee contract and am unable to set up wi-fi calling, I bought my S7 outside of the UK.
Highlighted
by Brilliant Contributor
Solution
Re: How do I set up wifi calling on a Samsung S7 bought outside the UK?
Yes you would need to go to sammobile and download the firmware it would be best to get the latest EE nougat one as that will also support 4G calling but it's not on there yet as it was only released today.
there are a few good guides on there you will need to look up how to use Odin that's the tool for flashing
7 REPLIES 7
Highlighted
Where did you buy the phone?
Highlighted
Hi, I bought it in the UAE.
Sent from my Samsung Galaxy smartphone.
Highlighted
Can you dial *#1234# and post what comes up please
Highlighted
AP: G930FXXU1DQC4
CP: G930FXXU1DQC2
CSC: C930FOJV1DQC6
Model: SM-G930F
Highlighted
Wifi calling won't work without flashing the firmware on your phone to a uk version which involves wiping everything off the phone.
and can be a bit complex if you've never done it before
Highlighted
Thank you for the answer. Would I have to go to SamMobile? Can you advise
on the process? As I recently wiped my phone so don't have a lot stored on
it at the moment. Many thanks.
Highlighted
Solution
