Highlighted
by Contributor
How do I remove international call barring. Cannot use phone abroad.
Hi have tried resetting, changing network, etc etc, when I use phone it sats you cannot make this call. I am abroad already and number was working. Have put credit on phone. Assuming all international calls barred. It was working before. Have recently changed phone. Would appreciate your help. Thank you
Highlighted
EE Employee
Solution
Re: How do I remove international call barring. Cannot use phone abroad.
@Nike1
Not necessarily the SIM but your account.
What I would need you to do is give customer services a call using an alternative phone to have your account looked into.
Many thanks,
Lee
22 REPLIES 22
Highlighted
Hello there @Nike1
Can you send texts?
Was this working in the new phone previously?
Speak soon, Leanne 🙂
Highlighted
by Contributor
hi yes it was working try even sent me a welcome to the Caribbean text message. A friend put some credit in from uk then it stopped working .no can't send any text either. Thanks
Highlighted
Thanks @Nike1
Can you try texting BALANCE to 150 and let me know the reply?
Thanks, Leanne 🙂
Highlighted
by Contributor
Tried 150. Balance message failed to be sent
Highlighted
Thanks for trying this @Nike1
Are you able to select any other network in the phone settings?
Also, where did you purchase your new phone?
Thanks, Leanne.
Highlighted
by Contributor
Hi Leanne tried them all. Bought phone in Jamaica had iPhone but given trouble been fixed. It was the new phone I got message from EE.
Highlighted
EE Employee
Hi @Nike1
Glad you are now sorted.
Many thanks,
Lee
Highlighted
by Contributor
No still not sorted!
Nike1
Highlighted
by Contributor
Sorry 😞Barring still on.😞😞😞
Highlighted
EE Employee
My apologies @Nike1.
I thought the device you purchased in Jamaica had resolved your issue.
Are you using Orange, T-Mobile or EE pay as you go?
Many thanks,
Lee
Highlighted
by Contributor
EE pay as you go
nike1
Highlighted
EE Employee
Hi @Nike1
Please, can I get you to turn off the 4G signal and have 3G only then perform a manual network search and try to connect to Digicel or Flow?
Does this help.
Many thanks,
Lee
Highlighted
by Contributor
Hi Lee don't have only 3G setting have the following.
2G/3G/4G
3G/4G
2G
tried all with both Digicel and Flow no luck.
Nike1
Highlighted
EE Employee
Hi @nike1
Try 2G only does this help?
Are you dialing the UK prefix for number 0044?
Many thanks,
Lee
Highlighted
by Contributor
Have tried 2G yes 0044 and +44. Get we're sorry you're not allowed to make this call. Tried different phone same result
Nike1
Highlighted
EE Employee
Hi @Nike1
The issue will lie with the SIM, are you with anyone else that is using EE?
Many thanks,
Lee
Highlighted
by Contributor
Unfortunately no not in JA do I need a replacement sim?. If yes I can reorder and get friend to bring. Nex week.
Nike1
Highlighted
EE Employee
Solution
@Nike1
Many thanks,
Lee
Highlighted
by Contributor
Thank you Lee will do.
Nike1
