Highlighted
How do I ensure my old iPhone is unlocked from EE?
Highlighted
by Profile closed
Not applicable
Solution
Re: How do I ensure my old iPhone is unlocked from EE?
Hello @Alijenner56 try a none EE SIM in it. If the SIM works and the iPhone picks up a signal or asks you to connect to iTunes/iCloud to finish the unlocking process your iPhone has been unlocked.
If if you get the error message SIM/carrier not supported or the iPhone says no service constantly it is probably still locked to EE. 🙂
Highlighted
by Profile closed
Not applicable
Solution
Highlighted
Thanks Tom, it does all this so feel reassured.
Very grateful.
Alison
Highlighted
by Profile closed
Not applicable
You are welcome @Alijenner56 glad you are happy with the unlock and it has been successful for you. Come back to the community anytime if there is anything else you would like to know. 🙂
