Highlighted
How can I put a longer ring on my phone before going to voice mail.
Hello can anyone help I would like to put my ring for longer before it goes to voicemail. At the moment it is 20 seconds I have tried the mmi code **61*07953222222*11*30# but all get that the code is invalid.
i have a new Samsung S7Edge.
Patio.
Highlighted
Re: How can I put a longer ring on my phone before going to voice mail.
Hi @Patio.
Welcome to the community. 🙂
Please try **61*07953222222*11*25#.
If that doesn't work, please have a chat with our technical support team.
Fingers crossed for you.
Highlighted
Hi Chris
Thanks for that tried it again no luck all I keep getting is Connection problem or invalid MMI code.
I contacted the tech guys yesterday and all they could say was to use the code like you supplied.
Pat
Sent from my iPad
Highlighted
Thanks for getting back to me.
I've looked into this on our internal technical support systems, @Patio.
It seems the 20 second delay is the network default. There are no further instructions from our side to lengthen that at all.
I know from a personal point of view that the GSM codes above sometimes do help, but, unfortunately not in this case.
