by pwilden995
How can I find out where I use my data?
I've used nearlly 6gb of data this month. Typically I dont use more than 4gb, can I get an explanation to what app or something I am using that is using it up?
EE Employee
Solution
Re: How can I find out where I use my data?
Hi @pwilden995
To find out what is using the most data:
Settings > Mobile Data > App then displays what data is being used.
Many thanks,
Lee
6 REPLIES 6
by pwilden995
EE Employee
Hi @pwiden995 and welcome to the Community.
So I can try and help the best I can, please may I know which handset it is that you are using?
Many thanks,
Lee
@pwilden995  The information you require should be on your device if it logs what apps use what data.
by pwilden995
iphone 6
Regards
Paul
EE Employee
Solution
Hi @pwilden995
Many thanks,
Lee
@pwilden995  It might also be worth having a look at THIS
