Highlighted
Hi, i would like my old EE iphone to unlock and need an unlock network code
Highlighted
Solution
Re: Hi, i would like my old EE iphone to unlock and need an unlock network code
If the device had been on your contract for at least 6 months, even if that contract has now been cancelled, you can just apply using the Unlocking your device form as the Pay Monthly option and giving the mobile number that it used to have. It will first show your current phone on that number & ask whether that is the device you want to unlock? If not, you will then have to type in the IMEI of the old phone.
Highlighted
Did you buy this device yourself new direct from EE or is it 2nd-hand? The process & costs are different.
Highlighted
I upgraded to a newer iphone as i was due an upgrade. It is direct from EE. I am still in contract with EE but with a different phone. Thank you for your reply
Highlighted
by Skilled Contributor
Skilled Contributor
I believe you can request to unlock a phone after 6 months with EE, probably a small charge, but call 150 during opening times, they should be able to do that.
Highlighted
Solution
