Highlighted
Hi I want wireless in outhouse approx 20mts from house will booster pack work
I have EE brightbox 2 wireless router the signal just reaches outhouse 20mt away. If I purchase the EE booster pack would that get me a good signal to stream video TV etc. Anyone out there know the answer?
Highlighted
Solution
Re: Hi I want wireless in outhouse approx 20mts from house will booster pack wor
Yes, the EE WiFi Booster Pack is a Devolo dLAN 500 powerline extender that works by carrying the signal over your electric mains wiring. As long as the outhouse is on the same mains as the main building it will work for you.
8 REPLIES 8
Highlighted
@Gg0824  No no no.   That's a add on to allow more data not extend the range of the Wi-Fi signal for this you're better off buying a Wi-Fi repeater these can be purchased at places like curries PC World.
Like this ONE
Highlighted
Is your outhouse connected to the main house electrics?
If so then consider using powerline adaptors and either a Ethernet switch in tour outhouse or a wireless pass through
I have linked to the netgear equipment as it's what I use and would recommend.
Highlighted
Solution
Highlighted
@Gg0824 sorry my mistake I've never seen that page and I didn't know EE had these.  Sorry again for my mistake but try this ONE for the page that @XRaySpeX is trying to link you too.
You can still though use the one I linked to in my first reply though.
Highlighted
Funny. The link, https://eehomebroadband.com/ProductDetail.aspx , I gave works sometimes & not others :(.
Highlighted
Thanks for that. I will buy the EE booster pack device to keep compatable with the EE suplied router. Hope it gets me going now. The out house is supplied with a armoured cable from my house, and all leads go to the same circuit board. Being a outhouse the supply is obviously got its own circuit breaker in the outhouse but all the mains wires connect to the same master fuse box in my house. Will let you know how I get on when it arrives. Thanks for information.
Highlighted
@XRaySpeX  I just deleted
ErrorGeneric.aspx?aspxerrorpath=/ProductDetail.aspx
from the URL when it errors and it works every time with just
Highlighted
You're welcome :)! Glad I could be of assistance.
