by Elaine19741 Investigator
Hello. Does anyone know what a + in a circle means? At the top of my phone? Than
Solution
Re: Hello. Does anyone know what a + in a circle means? At the top of my phone?
@Elaine19741
That symbol represents that the data saver is on.
Data saver prevents apps from accessing the EE data network in the background (when you are on the cellular mobile network, and not on Wifi), and saves your mobile data from being used. Go to quick settings and toggle the data saver switch if you want to turn it off.
6 REPLIES 6
by Ace Contributor
HI @Elaine19741
Have you got Sony Xperia phone?
If is that must be data saver icon sign.
If you want to remove this go in your settings and data saver then turn this off.
https://support.sonymobile.com/gb/xperiaxa/kb/80193074063d82eaf01573b905dd7006da9/
by Prodigious Contributor
Hi. What kind a phone you use?
Solution
@Elaine19741
EE Employee
Hi @Elaine19741 and welcome to the community.
Hopefully the advice given above has helped with you mysterious symbol.
Many thanks,
Lee
Thank you all so much for help. Its now sorted.
I'm glad it's sorted, @Elaine19741. 🙂
Feel free to come back to the community if you have any other questions.
Chris 🙂
