Highlighted
by Contributor
Has anyone out there had problems with their Router please, turning off.
I have only had my EE4g Wifi box for a week or so. Plugged in to computer via LAN cable. Then started to act up in that all the lights on the box would go OFF except the blue WIFI light. Turned computer on, tried to connect to Internet, no connection. The ON/OFF switch on the front of the box did not respond at all. Pulled out plug, reset, all lights on and worked fine. Rang EE and they kindly replaced the Box. New box arrived, set up, exactly the same thing happened.  Rang EE and they sent me a replacement Sim Card. Set up, worked fine, then started again.  The box works fine once it has been unplugged and then plugged in.  Has anyone any idea at all of what might be going on or had the same happen. Oh running PC desktop with Windows 10. Build 1709. Thanks in advance.
55 REPLIES 55
Highlighted
Re: Has anyone out there had problems with their Router please, turning off.
@Pdoc  Does it turn off when your using the computer.  And what model 4G wifi device is it ?  Does it look like this
Highlighted
When this happens, can you connect to the MBB by WiFi? Does the connection drop then, even when the lights go off?
The lights on top are meant to go off to conserve the battery.
Highlighted
by Contributor
Hi Chris. Hope I have got this reply right. !!  No, it is a white box, and has the five blue lights across the front, and the On/Off button in the middle of the front. Thanks.
Highlighted
by Contributor
Also should say Chris that it onlt happens when I leave the machine on. Works perfect otherwise. ??
Highlighted
@Pdoc  So it looks like this
If that’s the case then @XRaySpeX I thought that this type was mains power only as its a home 4G router and not a portable device like the osprey.
Highlighted
@Chris_B: Tell that to EE Small Business Smiley Wink.
Highlighted
by Contributor
Hi Chris. Yes, thats what it is like, Plugged into the mains. Any ideas of what might be going on please. Thanks.
Highlighted
It will likely be power save which will activate when the device is not in use. Unlike a wired router this is connected to the 4G mobile network so acts differently. You can take a look under settings to see if there is any option to deactivate or extend this time.
There is also the possibility that you are not receiving a strong 4G signal. Have you checked where the device is located and signal strength locally?
  1. EE Coverage Checker;
  2. EE Network Status Checker;
 Thanks,
Highlighted
by Contributor
Hi Northerner, thanks for the reply. I have one bar showing on the signal indicator, and have a man coming this afternoon to fit at outside aerial booster. I am only 2 miles from an EE mast.   Cant see anything in settings, where should I look. Thanks.
Highlighted
@XRaySpeX  Tell what to small business ? And where does small business come into it ?   as I was only asking you as I thought you might know as this is not sold as a portable device but as a 4G home router.
A simple yes it does have a battery or no it doesn’t have a battery would of sufficed.   Please forgive me for asking.
Highlighted
@Pdoc
The settings are EE own firmware. Other posters have mentioned about these wireless devices turning off (I have the yellow one). EE need to update the firmware to allow the white one at least to remain online or for the sleep to be disabled.
The aerial might help if the device receives a stronger signal, but then again the sleep issue will remain until EE update the firmware.
Please let us know how you get on with the aerial.
Highlighted
Sorry, @Chris_B, no, it doesn't have a battery. I thought it did.
Highlighted
by Contributor
Hi all. Just a little note to thank you all for the replies to my Post.  I have just had the external Aerial fitted and done a test with Ookla.
Results are:
Ping 23
Upload:13.15
Very happy with results.  Now three bars showing.
Thanks again for your help. Regards, Peter Doc. Cumbria.
Highlighted
EE Employee
Hi @Pdoc
That speed is brilliant 🙂
Was the installation process straightforward?
Many thanks,
Lee
Highlighted
by Contributor
Hi Lee H.
That result was with the router connect to the computer by LAN.
Just done a test pure WiFi and the result is:
Ping: 44
Upload: 5.42
The installation was quite easy and I had it done by a local man up here in the Lake District. First class job, and it definitely makes a big difference.
Highlighted
EE Employee
Hi @Pdoc,
Let us know how you get on.
Many thanks,
Lee
Highlighted
by Established Contributor
Hi there, I'm having the same problem with the same model of router which I received about 3 weeks ago.  The only solution appears to be to switch off mains power for a short while and then power back up.  The router freezes with just the WiFi indicator lit.  I've checked the router's firmware is up to date and performed a reset.  I've contacted EE who are arranging for a replacement to be shipped to me tomorrow.
There are other threads indicating that other users have experienced this problem.
Aside from this I'm very pleased with the 4GEE router now that I've also had an external antenna fitted (good job by TSG).  Latency = 204 ms, Download = 45.2 Mbps, Upload = 27.8 Mbps.  Not as good as some perhaps but compared to the slow satellite broadband I was using and I now have 200Gb a month data limit compared with 40 Gb before.  Night and day!
Simon
Highlighted
Hello there @psimanc
Thanks for coming here.
Let us know how you get on with the replacement.
Speak soon, Leanne.
Highlighted
by Contributor
Hi Simon.
I also had a replacement which acted in exactly the same way.  They then sent me a replacement SIM card. Which again acted the same way. ??  I then had the external aerial fitted, signal strength went from one bar to three bars, and the speed was / is amazing.  I have not had any episodes since the external aerial was fitted. !!  I use teh wireless part of the router and the LAN cable.  The LAN cable to the computer is much faster.
All seems to be going very well.  That's all I can tell you really.
