Highlighted
by Valued Contributor
Valued Contributor
HTC One M9 - Locked or Unlocked
Hi
I have a new contract with EE and am selling my old HTC One M9 to my friend who wanted it unlocked before she buys.
I got a 3 Sim to use so that I could test  if the unlock worked however before I unlocked it I stuck the 3 sim  in my old EE phone and it worked straight off on the 3 network no unlocking needed.
I am a tad bemused?
I thought EE phones were all locked?
8 REPLIES 8
Highlighted
Re: HTC One M9 - Locked or Unlocked
Did your upgrade the M9 via EE direct/EE store or a third party?
Thanks,
Highlighted
Valued Contributor
Hi Northerner,
It was from a third party (Affordable Mobiles)
thanks
Highlighted
@sounds
EE don't provide third paty sellers with handsets so these phones so it will likely be unlocked by default. Most third party handsets are sourced from the EU so unlocked.
Phones running EE firmware or from EE direct/store will be locked to EE.
Thanks,
Highlighted
Valued Contributor
Many thanks for explaining!
Highlighted
EE Employee
Hi @sounds,
Glad you got the answer you needed 🙂
Many thanks,
Lee
Highlighted
Your new phone may be unlocked cuz you got it from Affordable Mobiles, but that doesn't apply to the HTC. Where did you get that?
Highlighted
Valued Contributor
I got it from Affordable,
Highlighted
EE Employee
Hi @sounds
It should be unlocked when bought via a third party site.
Many thanks,
Lee
