by nnnnick Investigator
Gifting data
The gifting data option doesn’t work on the my EE app
it tells me to try later- but I keep getting the same error message.
app is updated. Have plenty of data available to gift.
Any ideas?
8 REPLIES 8
by Skilled Contributor
Skilled Contributor
Re: Gifting data
@nnnnick, have you tried deleting the app and then download it again?
Re: Gifting data
Thanks- I tried that but no good
I get the same error screen that others have posted (attached)55A07246-B462-415A-ADB4-952D093F2910.png
Skilled Contributor
Re: Gifting data
@nnnnick, Is the person your trying to gift data too showing on your account? They need to be to gift data.
Re: Gifting data
Yes the person is listed under ‘family useage’- see screenshots
Re: Gifting data
Skilled Contributor
Re: Gifting data
@nnnnick, I’m stuck! Lol. I’d advice you to call CS tomorrow and speak to Technical Services. I’ve checked mine and everything is working fine, thought it might be a technical problem with EE, but it seems ok.Let us know how you get on
Re: Gifting data
Will do
appreciate your help nonetheless!
Re: Gifting data
Hi @nnnick
I've had a look at this too and cannot figure out why it isn't working.
Let us know how you get on, once you're spoken to customer services.
