Highlighted
by Investigator
Fingerprint scanner on LG k10
Does anyone know how to get the fingerprint scanner working on the LG k10 2017
Highlighted
Re: Fingerprint scanner on LG k10
Is it broken or have you deactivated it? If so look under settings - security.
Highlighted
Hi @Scottymoe
Welcome to the community. 🙂
To add a little to @Northerner's response, it should be under security and fingerprints of the privacy section.
Hope this helps.
Highlighted
by Investigator
I cannot find those settings on the phone
Highlighted
Hi @Scottymoe,
I've looked into this for you and the European version of this phone doesn't include a fingerprint sensor.
The button under the flash on the back of the phone is a Power/Lock key.
