22-06-2017 02:40 PM
Hi. Anyone else having same issue
Facebook wont load photos on 4g cant see any videos or photos same with instagram...
If i connect to wifi it works fine. Tried simcard in another device and works fine also..
23-06-2017 11:05 PM
This is the solution that I worked out
If you have a samsung phone do the following:
Go to connections
Mobile networks
Access Point Names
Click ADD
name is Internet 2
APN type 'everywhere'
leave all the rest blank... Now try..
Does this work?
if you have iphone it's same procedure just find your access point networks
22-06-2017 01:24 PM
Same here.. Instagram doesnt load either... I've contacted support but nothing they dont know whats wrong. Works in another device though,
22-06-2017 04:55 PM
Hi @liamcabble and welcome to the community.
Are you still seeing an issue, what type of device is it that you are using?
Many thanks,
Lee
22-06-2017 06:41 PM
Samsung s7 edge my girlfriends don't work eithrr hers s6
tried everything delete cache deleted app reinstalled app tried everything you can think of.
Instagram or.faceboom not working seen another threat with something similar works on wifi just not 4g tried my SIM in another phone and works fine
22-06-2017 06:45 PM
just found a tempepry solution...
on android I went o data and changed from 2g 3g 3
4g to just use 3g only and it's working I went back to 2g 3g 4g auto connect and stopped working so it seems to me something is up with that can you look into this?
22-06-2017 06:58 PM
Hi @liamcabble
Please do get in contact with our technical support teams as they will need to run a diagnostic.
Many thanks,
Lee
23-06-2017 04:04 PM
Literally have exactly the same issue the last 2 days. Data not loading for FB or Instagram and EE app not even opening
23-06-2017 04:25 PM
Hi @Katebey92 and welcome to the community.
Have you spoken to our technical teams to run a diagnostic?
Many thanks,
Lee
23-06-2017 04:25 PM
Hi there i was wondering if anybody could help me,
Recently ive noticed a really odd problem when im on 4G. Apps like facebook and instagram wont load images or play video when im on 4g. Everything works fine, i can connect to the net, use whatsapp, gmail, speedtests ect, just images wont load on certain websites. Ive tried logging in through a browser to facebook and i get the same outcome. everyting loads but the images and video. It works perfectly over wifi.
Ive searched lots online and cant find a solution. Ive tried resetting, cache clearing, making sure content filtering is turned off and nothing. the only thing that oddly works is forcing my phone into 3g. when i do it, everything loads absolutely fine. I only noticed this problem a day ago and it was working fine up until then as far as im aware. Im on a galaxy s8 and on a monthly plan.
ive attached images so you can see how it looks
23-06-2017 04:28 PM
have litereally the exact same issue and just made a post about it before finding yours. any luck in fixing it? youtube works also but runs slower than usual. im on a galaxy s8. works fine in 3g but obviously using a 5mbs connecting when youre paying for 100 is not viable. doesnt work through the app or the browser so i assume its on EEs end?
23-06-2017 04:29 PM
Hey Lee no not yet, how would I go about doing that?
23-06-2017 04:31 PM
Call CS on 150 & report it.
23-06-2017 04:31 PM
Hi @Katebey92, @Shabab92 and @liamcable
I am going to send you a Private Message to gain some information for our support teams.
Many thanks,
Lee
23-06-2017 11:05 PM
Go to connections
Mobile networks
Access Point Names
Click ADD
name is Internet 2
Does this work?
24-06-2017 03:15 AM
I have exactly the same issue. I only got my new s8 plus a few days ago and social apps such as Snapchat YouTube etc take ages to load. Videos don't load properly nor do pictures.
24-06-2017 10:14 AM
I posted the solution
25-06-2017 10:15 PM
Hi, I have a Sony xperia X compact. Unfortunately this solution has not worked for me. I have found the only way I can get Facebook to load pictures is:
In mobile networks turn to 3g.
Wait a few minutes
Turn back to 4g
Facebook now loads pictures and video. But I have to do it every time I come of wifi. Very frustrating.
26-06-2017 09:32 AM
Hi @Melma26,
We are still investigating this issue.
Are you still having the same problem this morning?
26-06-2017 10:19 AM
Good morning James
Yes unfortunately so. It only started last week
26-06-2017 01:56 PM
Having the same issue as everyone else.
Have followed all advice but still not working. WIFI is fine but as soon as Im on 4g FB will not load any images and videos are extremely slow to load. Has just randomly happened as was fine before and nothing has changed since.
Please help
Subject |
