Highlighted
by Investigator
EE PAYG SIM in Osprey 2 not working, did I need a special SIM?
Hi. I've an Osprey 2 from an old closed business account and wanted to use it again. So I bought a new EE PAYG SIM, loaded some data and checked it was working etc in another phone. All good, but when I load it into the OSprey 2 nothing works, please help.
Highlighted
Re: EE PAYG SIM in Osprey 2 not working, did I need a special SIM?
@KBrennan   It should work.  But is the device working?
Highlighted
by Profile closed
Not applicable
Are you getting a signal when the SIM is in the Osprey?
If so and with it being PAYG, you need to activate the service.  Whilst connected to the Osprey try browsing to http://add-on.ee.co.uk/status and follow the 2 step activation process there.
Highlighted
by Investigator
its flashing a single red light in the 4G light
Highlighted
by Investigator
the device doesn't seem to be working. I can't connect to it anyway.
Highlighted
Hello there @KBrennan.
Does the Osprey work with any other SIM card do you know?
You can also view our help and support pages for the Osprey 2 this advises how to reset the device if you are having problems.
Thanks.
