by DylanEE2 Contributor
EE I changed my ip and forgot to log out
So basically I was reserving an ip for the computer I was using to reserve it for. And I reserved the ip and didn't logout. Now it says. Duplicate Administrator - This device is currently managed by another user
by Profile closed
Not applicable
Solution
Re: EE I changed my ip and forgot to log out
Most routers usually log out users automatically after around 15 minutes or so just try waiting a while.
Failing that, rebooting your router should reset everything and log all admins out.
by Profile closed
Not applicable
Solution
