Highlighted
EE Brightbox intermittently drops internet
Hi
The EE brightbox 5ghz line drops out every so often making using the internet in a cosistent pattern impossible. Seems to be every 5 or 10 minutes for about 3 seconds.
Is anyone having this issue?
DSL STATUS
STATUS   ConfiguredCurrentLine StatusLink TypeOperation Mode
--UP
--Fast Path
AutomaticG.993.2 (VDSL2)
DATA RATE INFORMATIONUpstreamDownstream
20000 (Kbps)
79987 (Kbps)
DEFECT/FAILURE INDICATIONOperation DataUpstreamDownstreamNoise MarginLine Attenuation
12.1 (dB)12.9 (dB)
0.0 (dB)6.9 (dB)
Indicator NameNear End IndicatorFar End IndicatorOutput PowerFast Path FEC CorrectionInterleaved Path FEC CorrectionFast Path CRC ErrorInterleaved Path CRC ErrorLoss Of Signal DefectFast Path HEC Error STRInterleaved Path HEC ErrorError Seconds
-10.5 (dBm)-10.6 (dBm)
01567
00
00
0760
76117
STATISTICSReceived DataTransmitted Data
24491384 (Kbits)
30674244 (Kbits)
Speed Test: https://www.thinkbroadband.com/speedtest/1514072316469903055
Exchange: https://availability.samknows.com/broadband/exchange/EMKIRKB
Highlighted
Re: EE Brightbox intermittently drops internet
Both Linkys don't compute! Corrected (remove trailing space):
Highlighted
Yes, I expect someone's been messing around at cab/exchange.
Your BB connection looks fine. Are you saying just the WiFi drops?
How long's this been happening for?
Highlighted
Hi
Thanks for the reply.
This has been happening for a couple of weeks. It appears that its just the 5ghz wireless that drops out but i don't think its the 2ghz one. Sometimes when i press the button for the intelligent wireless the problem is sorted for a couple of hours.
