Highlighted
by Contributor
Re: Desktop link not working
Hi
Following my last post of two weeks ago can I assume XRaySpex has not been available or has my problem been forgotten or is there no resolution.
Regards
Robin
Highlighted
If you can't find any DNS setting it ain't there and so you can't change it in the MBB but you should be able to on your PC.
As I said earlier you don't really need to use the Web Connection.
Highlighted
by Contributor
Hi
Many thanks for all your advice and now consider the matter closed but not solved as it has not been, in that I can’t believe EE supply equipment that installs a link on the PC desktop that does not work as it used to before a software update and no one at tech support by their own admission have anyone who can give an answer.
Highlighted
Hi @RJB1,
I'm sorry our technical support team were unable to provide a solution, it's a very odd issue that I have never encountered.
Why not take up the offer of a replacement device?
Highlighted
by Contributor
Hi James
Thanks for your reply, I have taken your advice and taken up the offer of a new unit which arrived today together with a new sim, and have again followed the installation instructions, guess what still the same issue to which I can only assume it’s something to do with the latest firmware update as I’ve again installed it on a laptop that has never had on and still have the same problem.
Highlighted
EE Employee
HI @RJB1
Have you tried connecting via WIFI to 192.168.1.1
Does that work at all?
Many thanks,
Lee
Highlighted
by Contributor
Hi Lee
Have tried that and it works and have pasted to desktop thanks.
But have to say I still think this issue needs sorting why have a unit that installs software that does not work.
Many Thanks
Robin
