Highlighted
by Contributor
Desktop link not working
I have had a 4GEE MINI WIFI for eleven months and had no problem until three weeks ago when the unit would not switch on neither would the charging lights come on, now after the unit has been repaired the desktop link (Web Connection icon) does not work receiving the message (This site can’t be reached EE broadband’s server DNS address could not be found)
I’ve uninstalled the unit’s software cleared the registry (win10 64 bit) shut down rebooted and done a total re-install still the same. Tried installing it on a laptop that’s never had it on, still the same.
Then phoned tech support total waste of time told to wait for a software update, It worked ok before the repair Has anyone got any ideas.
26 REPLIES 26
Highlighted
Re: Desktop link not working
Hello there @RJB1
Did you receive the same device back from us?
Do you have a SIM card in the device?
Thanks, Leanne.
Highlighted
by Contributor
Hi Leanne
Thanks for your reply, regarding your questions I kept my sim card and the
repair report says
1, Updated device software to the latest version
2, Replaced the main board inside the device
3, Updated the device's IMEI to 357475073580519
Regards
Robin
[MOD EDIT: Please do not post personal details onto a public forum]
Highlighted
EE Employee
Hi @RJB1
Have you tried to factory reset the device to see if this assists.
Many thanks,
Lee
Highlighted
The Web Connection is unnecessary for using the MBB device, but as you have it might need uninstalling & reinstalling with new hardware & IMEI.
Highlighted
by Contributor
Hi Lee
Thanks for your suggestion that was the first thing I tried but made no difference.
Thanks Again
Robin
Highlighted
Hi @RJB1
Thanks for getting back to us.
Did you try uninstalling and re-installing as suggested by @XRaySpeX?
Highlighted
by Contributor
Hi
Thanks for the advice I tried doing a complete uninstall also cleaned the registry before doing a fresh install, also installed it on a laptop that’s never had it on and the link to the URL still does not work, I have now made two phone calls to tech support, Am not impressed.
Regards
Robin
Highlighted
Thanks for confirming, @RJB1.
I know you've said that you've already spoken to them on a couple of occasions, but, the technical support team are in the best position to be able to help you with this.
Highlighted
by Contributor
Hi Chris
Thanks for that, but have to say all I got was wait for a sotware update, Everything was working fine until the unit was repaired/replaced.
I'll give tech support another try.
Robin
Highlighted
by Contributor
Hi
Have again spoken to very helpful guy tech support but was unable to resolve this problem as he had never come across it before, so it seems there is no one a EE who can resolve this issue.
Highlighted
by Contributor
Although in my previous post closed it as solved it really was'nt as no one at EE could give me an answer and was told by tech support they had no one who could although the offered to replace my 4GEE mini device regetably I did not accept the offer.
Thank you all for your very helpful suggestions I may look for something better from another supplier when my contract finishes.
Highlighted
Good morning @RJB1
Thank you for posting 🙂
I'm sorry to hear that you feel this way and you haven't had the resolution you were looking for.
I hope you don't leave EE and you are always welcome here.
Richard
Highlighted
What DNS settings do you have in the device?
Highlighted
by Contributor
Hi
Thanks for your reply but where do I find the DNS settings
Regards
Robin
Highlighted
Hi @RJB1
I'm sure @XRaySpeX can guide you where you need to be when he is available.
Richard
Highlighted
by Contributor
Hi Richard
Thanks for that, perhaps @XRaySpeX  could let me know the times he will be available
Regards
Robin
Highlighted
Hi @RJB1
@XRaySpeX is available whenever he has time to kindly lend a hand to others.
There are no set time, but as and when he is available I'm sure he will help you.
Richard
Highlighted
I don't have an MBB up & running at the mo', but you should be able to navigate its menus looking for DNS if it's there.
Highlighted
by Contributor
Hi XRaySpex
I've been through every menu and settings on the BMM and cannot find any referance to DNC, could this be a result of the recent software update? Vr EE40_00_02.00_43
Regards
Robin
