Highlighted
Data not working
Essentially I originally thought I had 2GB of data, but after checking on EE sites it turns out I actually have 5GB of data per month.
This month it turns out I still have 1.7 GB left out of the 5GB , but my data doesnt even think about beginning to work.
Is it an error that it says I have 5GB? or if not why has the data stopped?
Highlighted
by Ace Contributor
Re: Data not working
HI, @iogrdsgre
Text AL to 150 and check what response you get?
And you can also check data status here http://add-on.ee.co.uk
Make sure use your mobile Internet not on WiFi.
Many Thanks
Highlighted
EE Employee
Hi and welcome to the community @iogrdsgre
So I can try and assist, please let me know what type of device it is that you are using.
Many thanks,
Lee
