Highlighted
by Established Contributor
Chromecast
I have an Orange gigaset se572 router and was wondering if this would work with Chromecast?
Highlighted
Solution
Re: Chromecast
Well, the Siemens router does 2.4 GHz 802.11 b or g WiFi, so it should be OK.
A USB is not a display port. You've effectively downgraded your tablet in that respect.
6 REPLIES 6
Highlighted
Re: Chromecast
No reason not to. It's just a wireless device.
Highlighted
Re: Chromecast
Thanks for replying @XRaySpeX. Was just the tech requirements for Chromecast threw me, 802.11 b/g/n (802 11n at 2.4ghz only) with wep, wpa and wpa2.  On digging around I think just standard router blurb.
Getting new android tablet. Old one had micro hdmi and I had cheap long cable running to tv hdmi for occasional use, but not on new one, only usb otg, and can't see an easy cheap way to connect to tv.
Highlighted
Solution
Re: Chromecast
Highlighted
Re: Chromecast
Thanks @XRaySpeX, couldn't find decent tablet with hdmi. Think it may be possible with usb otg but complicated and no cheaper than Chromecast.
Highlighted
Re: Chromecast
Isn't USB OTG just Micro USB -> Std USB? Still think it won't provide a display signal like HDMI. It's just a port converter.
Highlighted
Re: Chromecast
Seen articles that imply its possible with adaptors and cables, so not sure whether it just a little usb or has other capabilities tbh! Chromecast just looks easiest, cleanest solution.
