by Bradenleesteven
Changing my number
I've been getting prank calls non stop with a withheld number. Was wondering if I can get my number changed.
by Ace Contributor
Re: Changing my number
Here is what I found on EE help page : http://bit.ly/VASqHN
You can get your number changed, but I wonder how long the process will take. I guess the quickest way to do is order a free pay as you go SIM card online, then ask the PAC code from the SIM card provider then port-in to EE.
Smiley Happy
by Ace Contributor
Btw, are you using an andriod phone ? I remember certain models of android phones can block unwanted calls through settings.
by Bradenleesteven
Nope it's an iphone Smiley Sad
by wathman Established Contributor
You can't just buy a payg and port it in. The main number (of which you are currently using) will always be active underneath. You must phone EE and follow their process.
by graemesmith Contributor
Even better, why not call 150 and make an official complaint.  Even though the subscriber witholds their number the network can still get it.  If they have called you enough times to constitute a nuisance then EE should report them to the regulator and get their service stopped regardless of what network thet are on.  I'd still get your number changed as well though.  EE should be able to do that quite quickly.  O2 can do it in a matter of hours.
Former EE Community Manager
Hi Bradenleesteven
I agree with the suggestions posted above: change your number, and report the prank caller as well.
Follow this link for information about blocking calls.
To change your number call EE customer services on 150.
C
by Skilled Contributor
Skilled Contributor
I had same issue. Try answer the call so it connects. The. Keep call active for 3 seconds. If they hang up then fair do's. but if you want log the times it happens then trot to your local police station and make a complaint about harassment calls. They have to investigate it. This meaning they can find out from the network who is calling you and go have a polite word. If it carries on. Then report it again and then you can get a crime ref number as its classed as harassment and that's a crime in this country. Lol. And then contact EE they will have to change your number with no questions asked.
