Highlighted
by Investigator
Can’t connect to 4GEE WiFi from laptop
I recently started using the 4GEE WiFi (payg). All was fine for a couple of weeks, could connect both my laptop and iPhone to the network. But in the last couple of days my laptop has stopped connecting to the WiFi. The laptop recognises the WiFi and the signal is strong, but when I try to connect to it, I get an unable to connect message. I can still connect on my iPhone just fine.
any suggestions?
Highlighted
Re: Can’t connect to 4GEE WiFi from laptop
Forget the connection and connect again fresh.
Highlighted
by Investigator
Hi northerner
i just tried your your advise and still get no connection
Highlighted
by Investigator
I seem to have fixed the problem
i just turned of the EE MIFI for about 30 seconds, then turned it back on and I was able to connect again.
Thanks for for the help. Hope this helps others
Highlighted
Hi @dib83,
Welcome to the EE Community. Smiley Happy
I'm happy to hear a reset fixed the issue for you, thanks for the update.
