by kieron86
Can I turn off GPRS AND EDGE Frequency?
Is there anyway that I can disable my phone from using GPRS and EDGE? (and just use 3G and 4G) It's about as effective as using data with the phone in Airplane Mode! Thanks.
by Ace Contributor
Re: Can I turn off GPRS AND EDGE Frequency?
Which phone do you have? Not all support the ability to do so.
Unless it allows you to do this under network settings then no you cannot.
Depending on your phone you could check the apps store, as there might be an app which you could use to use force these settings.
by kieron86
iPhone SE.
by Ace Contributor
2G cannot be turned off on the iPhone SE.
EE plans to increase their 4G coverage so it exceeds that of 2G, so you should not experience 2G in coming years.
