by squinthorizon Valued Contributor
Valued Contributor
Re: Can I get a Nokia 6 to work with EE wifi calling ?
Hi Leanne. It was a month ago that I originally asked the question. Is there still no answer? If the Nokia 3, 5 and 8 will work, then will the 7 plus work too?
EE Employee
Hi @squinthorizon
I will certainly check up with @Leanne_T for you.
Many thanks,
Lee
Valued Contributor
Lee / Leanne...... still no definitive answer?
Morning @squinthorizon.
I have chased this now for you and will get back to you as soon as I have an answer.
Thanks, Leanne.
by walesfarmer Contributor
Hi, did you manage to find out if volte & wifi calling work with a nokia 6.1/7plus from CPW with an EE SIMO? Thanks
by Ace Contributor
Do you know anyone with a EE pay monthly SIM card you could use to test in your Nokia 6 to see if you can use EE WiFi calling ?
I havent purchased it yet, and no is the answer to the second
by Ace Contributor
Do you have a EE store near ?
so they can test a sim in there for you.
