by dougoutcanoe
Can I connect my printer to the Brightbox USB as a print server?
I cannot find any help in the manual for the Brightbox, on other uses for the USB connector.
I would like to connect my printer to the router via USB for printer sharing.
Is this possible?
Should I just plug the printer in and try?
Could this damage anything that Windows Vista hasn't already?
by brightbox Investigator
Re: Can I connect my printer to the Brightbox USB as a print server?
I am having a similar problem.  I cannot find any help on the net although EE technical advisor said it can be done
by sgl5gjr Established Contributor
If you have enabled networking on your computer.... and can find a usb pen drive on the brightbox....I can't see any reason why you cant print via the same method via Samba.
I have a printer on a Linux OS running netbook... the printer is shared via Samba.... we are on Windows and Android and print via the netbook
On the windows computer ...you search for a printer and it should find it....then when you click add it will ask for drivers.....ignore the make/model of the printer and chose Generic Printer then chose MS imagesetter driver and click yes/add or whatever it says whatever then you should see "print test page"..... Click that and if it worked you should have a test page
by Profile closed
N/A
by DenisOxon Investigator
I have done it with brightbix 1 and 2.
