by brendantravis Investigator
Can I change the delivery address for a replacement sim?
I've already ordered a replacement sim but it never gave me an option to choose a delivery address. I assume it will be delivered to the billing address but being a student, that address will not do. Is there any way to change the delivery address after the request has been sent?
Also, will this cost anything? I've seen numerous posts that it does but on the page I requested one it didn't say anything...
Solution
Re: Can I change the delivery address for a replacement sim?
No it will go to your billing address.
You can always pop into a store and get a replacement there for free.
Brendon
If you think I helped please take time to press the button below
Community guidelines
EE Contact Details...
150 from EE Mobile
0800 956 6000 (Option 5) from any other phone
0800 079 8586 Home Broadband & EE TV
Solution
Brendon
150 from EE Mobile
Thanks.. Is there anyway I can cancel the order so I can just go into a store?
You can just go to store anyway.
Of you order another reacement it deactivates the one that has been sent so no one will be able to use it.
Brendon
150 from EE Mobile
Thanks, I'll do that. And is there no cost to the one being sent?
What network brand are you on?
Brendon
150 from EE Mobile
I'm on Orange.
Then a replacement is free regardless of channels you take.
Brendon
150 from EE Mobile
Thanks for all your help. You've been of great assistance this evening!
