by jakabakos
Can I apply for a monthly plan without having a local UK address?
I`m arriving to the UK next week to start job, and I will need a local phone number ASAP. Since I don`t have a permanent address yet, I`m concerned if I can apply for a montly plan. I only need a SIM card with monthly payments (I already have my phone).
by Ace Contributor
Solution
Re: Can I apply for a monthly plan without having a local UK address?
@jakabakos
You need  permenent address in the UK. As EE need to credit check before give you a new SIM only contract.
But you can always get pay as you go some deals available on pay as you go please click here http://shop.ee.co.uk/sim-only/pay-as-you-go-phones
Many Thanks
by Ace Contributor
Solution
@jakabakos
Many Thanks
by jakabakos
Thanks for your reply.
So you mean that for the pay as you go I wouldn`t need premanent address, is that right?
by Ace Contributor
@jakabakos
Yes that is correct . you can visit on any ee store http://ee.co.uk/store-finder
Many Thanks
by jakabakos
Thanks.
EE Employee
Great info @tahirmian
Hi @jakabakos
If you need anything else you know where we are.
Thanks - Karen. Smiley Happy
